OneStepAhead
- Jul 28, 2006
OK, I have a Scythe Ninja heatsink that I am installing right now and we did everything right; however, when we put in the mounting bars. We put them in parallel with the processor bar, instead of oppisate side of it. Now the problem is that the four clamps do not reach the four holes completely. If put down even, none of them reach. When two are clamped in, the other two are way above it. The only solution I can think of is to swtich them around however I have to re-do everything. Is this the reason? Should I attempt it? Could it actually make a difference? And also, is there a simple thing I am missing.
LGA 775 Board
And also I did not undo the protectice film from the heatsink base. Could that make a difference even though it is extremely thin?
Help, THANKS IN ADVANCE!
LGA 775 Board
