The Scythe Ninja is officially THE MOST ANNOYING HEATSINK TO PUT ON. Were the instructions translated by a fucking 12 year old kid in Malaysia?!?!?!? (Probably). But man on man, it is annoying. About to go test right now. Oh, btw, its enormous.
MrGuvernment said:complaining is no good with out pics![]()
iSkylla said:The Scythe Ninja is officially THE MOST ANNOYING HEATSINK TO PUT ON. Were the instructions translated by a fucking 12 year old kid in Malaysia?!?!?!? (Probably). But man on man, it is annoying. About to go test right now. Oh, btw, its enormous.
Haste266 said:its not hard to put on...but i thought i was going to break something when i had mine.
i sold it promptly.
the ninja is not made for uncapped cores btw![]()
Elec said:I just put mine on a couple days ago and wasn't a fan of the mounting crap. The backplate is metal (ok, so it has a thin layer of foam). You could potentially short something out with it, although it's unlikely. The adhesive didn't help it stick to the board. It was slightly curved, so it didn't lay flat against the board until I cranked the retention bracket down from the other side. Then as has been mentioned, the four retention clips work, but aren't the easiest thing in the world to clip on. I even had a somewhat hard time clipping the fan onto the heatsink, since the little clippy things are thin and like to bend themselves out of the grooves on the side of the ninja.
I got it all put together and fortunately, it cools well. Heatsink design, good. Various retention designs...eh.
[H]Opterown said:Wish my temps were that good. Idle ~40C. :-/
jcll2002 said:is it harder to put on than the zalman 9500? What im asking is for someone who hasnt installed a hsf before, what would you reccommend?
Meanwhile the zalman screws into the mobo, which is also simple and easy to do.The Thermalright XP120, the Zalman 7000/7700, Scythe's earlier models all were more trouble to get on. The Ninja was much easier.
jcll2002 said:i thought you had to remove the mobo anyway. I have a removable mobo tray so it shouldnt be that hard, right? Also, if i do remove the mobo, should I take off the hsf that will be installed on it already, remove the grease, add as5, install the 9500, and then add the mobo back in with the 9500 already on it?
Nuff said for meiSkylla said:I find Zalmans to go on easier than the Ninja. Ninja was a fucking pain in the Butt.
i read that, is it bad if i use something other than my heatsink to spread the arctic silver? my friend used something flat to spread itquadnad said:As for installation, It's a better idea to remove the HSF with the motherboard still screwed into the standoffs (I find it easier that way). Once you've removed the stock HSF, remove the motherboard, clean off the old paste (with rubbing alcohol and a lint-free cloth), and unscrew the stock bracket. Install the new bracket, add a DROP of AS5 (if you doubt how much to add, follow this picture and these instructions starting at #9 if you get lost). Now install whichever heatsink you bought, and slap everything back in your case. boot up the puter and enjoy your oc'ing headroom![]()
hm, i'll try thatWhyYouLoveMe said:Ahhhh the age old question: To spread or not to spread?
I usually just drop the AS5 on the CPU and then mount the heatsink. It spreads itself and in every direction. I fear if I spread it myself I'll make tiny air pockets or bubbles and THAT, my friend, is bad.
rox1co said:hm, i'll try thati'll post my results and if they suck i won't love you
i don't get my 9500 till thursdayjcll2002 said:somone do them both and post back here asap please
rox1co said:i don't get my 9500 till thursdayi'll do both for fun and post my results
1 day just a dab, the next spread
its proven that not spreading the as5 and just leaving it there for the weight of the hsf to spread is the best way?quadnad said:It's already proven that using just a small dot is the best way to apply thermal paste, as not only does it ensure that there are no bubbles, but it also allows for the thinnest coat. Search around the forums a bit if you'd like, but I guarantee that you'll get better temps by only using a dab of paste.
Also, to whoever was worried about killing a cpu, just by spreading the paste you won't fry your CPU, you just won't get the best temps.
jcll2002 said:its proven that not spreading the as5 and just leaving it there for the weight of the hsf to spread is the best way?
yeah, i bet $10 on quadWhyYouLoveMe said:Alright, now... Quadnad and Warlust... FIGHT!![]()
iSkylla said:I agree 100%. Wasn't it scary with the four clip things? Didn't you think you were going to crush your CPU?
that sounds right. btw, nice rig you got there![H]Opterown said:My idle temps are higher than your LOAD temps lol. I know it can't be running that hot. I heard Asus boards read high so I'm not worried.
