Scythe Ninja - Good for Gaming?
chicabobo
I am building a PC for my girlfriend who's into gaming but she wants it to be super quiet. So I was wondering, if I run a AMD 64 4000+ with the Scythe Ninja will it be fine passive, or should I use it fanned? I imagine it will get really hot under load during gaming (World Of Warcraft) and dont want to toast the new and pricey cpu. I have great air flow through the case so that shouldnt be an issue.
I was hoping someone is also using the AMD 64 4000+ or similar with the Scythe Ninja and could tell me if that would be a good choice. If not and a fan should be used with that setup, would the Scythe Katana be a better choice than the Ninja?
I realize I could use a low speed 120mm, but I want to know if I could use the Ninja in the silent passive mode without a fan with the cpu I mentioned under load without frying it.
why take the chance.. just get you a fan regulator and keep it on low.. turn it off if you want, or to full speed if you want..
its safer to have it and not need it, than need it and not have it
-Evil Juggalo
A lot of the people at SPCR can comment further on this, as many own a Ninja. I'd go look around there if you're interested.
You could get away with it as long as you've got a 120mm fan removing heat in the back of the case. A front and side intake would be nice too.
according to scythe:
CPU Clock Speed Limit:
This product is not recommended to use with a high CPU frequency under the fanless mode. If you plan to use this item under fanless mode, your CPU load should be limited to low-middle loading. For high-end usage, we recommend to use an optional 120mm fan. Please use this product at your own risk.
I don't think I would go fanless. You can try it, but keep an eye on temps.....I just don't think it'll work well naked though. But with 2 fans...... :D it keeps my OC nice and chilly.
Edit: Even with one fan it was very quiet, and performed great. (2nd fan dropped temps another 5c)
Thanks for the ideas. I think I will take your advice and use a 120mm fan with it just to be safe. They have an option to select a Nexus 120mm Silent Fan so that should work out well. That is unless you guys know of a quieter 120mm with decent air flow. At only 22 dba that should be quiet enough for her. Maybe I will toss in some noise dampening material in the case just for the heck of it too.
