A few weeks ago I'm playing around in Windows when all of a sudden my computer freezes.
I hit reset, black screen. I let it sit for a while, try to start, nothing. I can see my DVD ROM flashing like the computer is rebooting, and it appears to be in a reboot cycle, never getting far enough to post info on the screen.
I press reset a bunch of times, I hear it BEEP, and loads up showing the processor.. it freezes. Hit reset again, black screen... I keep doing this, and the farthest I got was it started to load windows, and it froze. After that, it never got that far again.. it would only get to show the processor information and it would freeze.
I pulled all my components out, laid the motherboard on my desk. Took off the Scythe Ninja, cleaned everything up, reseated it, and again nothing.
My friend looks at my video card, finds that a resistor has been ripped off. This happened when I was pulled out my ram.. the little latches that hold the ram in clipped off a resistor. So I sent my BFG back, 2 days later got a new factory sealed BFG card. Plugged it in, black screen.
I noticed once my computer started beeping, it gave me 7 continuous LONG beeps, then stopped. So I started a process of elimination.. pulling out components to get different beep codes, starting the computer with no processor installed, no SATA drive plugged in, no RAM, etc.. still NOTHING! No beeps, no post no nothing! I looked up beep codes on an Asus board, found something about 7 beeps being a processor.. but I'm not sure if this was specifically for my BIOS.
So after pulling ALL my hair out, I come to the conclusion that either my Asus board is fried, or my processor is fried. But WHY is it sometimes posting processor information on the screen, but 90% of the time it's just a black screen? My temps were great, 30 celcius on a P4 640 3.2ghz. That Scythe Ninja performed amazing IMO. And yes, I reset the CMOS a bunch of times, pulled out my battery for 12 hours, etc.
So I get to the computer store where I bought this stuff (Canada Computers in Waterloo, Ontario). I tell them either my board, processor, or RAM is cooked. I brought with my my processor and RAM. I read on a lot of forums that this is symptoms of bad RAM. They take a socket 775 board, plug my processor in, along with the stock intel cooler I brought with me (which I haven't used in months), plugged in my RAM, plugged in on board video, and voila, it posts, and loads everything fine.
Now I'm just baffled.. WTF could it be? It HAS to be my board now, coz my power supply (Antec 550W) can't be bad... The guy at the store says it's most likely my BIOS. He said re-flash the BIOS and it should be all good. I think to myself, how the HELL am I supposed to reflash the BIOS if all I get is a black screen 90% of the time? And the other 10% of the time it won't get any further than saying P4 640.... freeeze.....
Now I'm kinda pissed, because in order to return my board under warranty, I have to remove that massive Scythe Ninja backplate that was double sided taped. This will be a mission, and I don't want to damage the board coz then they won't take it back!
So I Google 'remove scythe ninja backplate', and I find an article by accidentally clicking this link which says how a guy had the exact same symptoms, and it was the heatpipes on the Ninja touching capacitors on the board, shorting out the board! I nearly fell off my seat when I read this... I ran to my computer, took the Ninja off again for the 100th time, and attempted to seat the stock Intel heatsink + fan. I got it on there pretty tight, but I couldn't click it into place because of that backplate. I start the computer, VOILA!!!!!!! IT WORKS!!
Can you believe it? I would have NEVER guessed that. I removed the backplate after reading a post on [H] forums, cleaned it all up, mounted the Intel cooler properly with AS5, and it works flawlessly.
*SIGH OF RELIEF*
So if you ever get an aftermarket heatsink, make sure you know it's not touching any components!
Thanks for reading my story
*SIGH OF RELIEF*
