scythe mine
filthysanchez
i've been reading reviews and it appears to be decent.
does anybody have any actual experience with this cooler to enlighten me wiht?
pictures, perhaps?
noone has this?
well, i don't want to make a new thread for this, but can osmeone tell me how to change the names of everything in speedfan?(4.31)
If you can afford the ninja, or Tuniq go for that , but I have this cooler and it's done its job. See sig for system details. :)
These are core temp numbers btw...
i bought it, but i was just wondering how well it did.
i got the thermaltake 130 mm fan to go with it too.
Same as the others.. I've got one on my sister's machine, 3400+ Venice @ 2.6ghz. The machine runs 100% load whenever it's on (Folding@Home) and it lingers with her chip around 38-40c after running 100% load for a while (at least several hours). Could be better I guess, but her box is a DEAD silent rig (loudest thing is the hard drive which can be faintly heard) and has a couple of cathodes inside the case as well... it's a good cooler, very quiet. Very dense fin setup, I guess thats how it works so well being so small.
Looks sweet through a window too :p
IMO, good alternative to the ninja if you can't fit the ninja in your case (only reason I got it in the first place, she's got a small case).
i had the mine before i went to water. its a great heatsink and the best part is that you can use almost any size fan you want in it.
well, i have the mine in now, and i've seena ten degree decrease in load temps from the stock AMD heatsink, even with a small boost to 2.4 ghz(athlon 3500+/didn't have it OC'ed on the stock HSF)
of course, i keep my ambient extremely low in my room(about 15 C, just how i like it, with the highest being about 26 C during the summer)
