Scythe Infinity is ABYSMAL.
Dark_Legacy
Hello everyone, it's me again - the great gigantic newb.
Anyway, I had the absolute misfortune of being one of the poor suckers that bought the Scythe Infinity. Let me tell you, I've never had as much trouble with ANY computer component as I've had with this worthless, Chinese labelled peice of crap.
Let's begin with the finer points of the Scythe Infinity. It's large, it's got tons of fins, and it's got a 120mm fan that you can mount in the any direction.
Now, let's begin with the almost infinite list of HORRIBLE things with this god forsaken piece of metal I refuse to even call a cooler anymore.
You want to mount the fan? Sure, no problem. Just put it on and put metal brackets into the little 120mm holes that keep falling off. Next, try to position it in some unforgiving manner to even get you to push the thing into the "sockets" on the actual heatsink, which NO human can POSSIBLY do with their thumbs as they'd shove half an inch of metal into their thumb by the time you get the damn bracket on. I had to use all of my strength and a screwdriver to actually put the damn 120mm on and then once I applied Arctic Silver 5 to my processor and placed the damn thing down, it touched the other fan on the side of my case, and prevented me from plugging in the PSU wire that connects power to the CPU side of the motherboard. No problem, I thought.. well guess again. I extended the CPU wire as far as it could go, and tied underneath my side 120mm exhaust fan and tried to put the cooler in again. It couldn't fit with the wire standing there, it simply couldn't. Ok - I thought maybe I have enough airflow with my two 120mm fans in my case. I had one fan blowing air in from the top of the case with a grill on it to prevent dust from coming in and one from the side. Passive heatsink for the CPU. Well, guess what. I got the heatsink actually inside of the case, but then to push it down was absolutely impossible. I was barely able to get a flat screwdriver into the side to try to ram it in and with all of my force, I simply managed to tilt the heatsink on one side and to scrape some paint off of my motherboard. Refusing to give up, I kept trying various positions and re-applying the Arctic Silver 5, again and again and again and again.
After 50 consequtive tries, the verge of crying and FOUR freaking hours wasted, I gave up and had half a thought about throwing the heatsink full strength out of my window and into my neighbor's backyard.
So I implore you all: DO NOT BUY THE SCYTHE INFINITY. IT'S THE WORST HEATSINK EVER.
I have mounted my old heatsink with one fresh appliance of Arctic Silver 5 which took me five minutes. I will be sending back this heatsink and donating my $50 to charity.
I hope that everyone else on this board never has the misfortune of going through what I just did.
I have it. My only complaint is the stupid thumb socket things. Almost broke my mobo in half. Not to mention I think I screwed up the application of the Artic Silver because I was adjusting the heatsink so much to try to fit in the thumb sockets.
Thank you for your sympathy.
For everything thinking that I'm insane, here's a picture of the thumb sockets:
You can't even fit your thumb in-between the fins and the thumb sockets!!
