One more SCVMM question
One item I am investigating is doing a SCVMM cluster. I know its an active/passive setup which is totally fine, but I would ideally like to set it up across two physical locations. Basically, when this system goes full production, I would like one of our pilot offices having the passive node and in case for any reason, the main office SCVMM node goes down (server or network wise), it will pick up the slack.
My understanding so far is that SCVMM must be a VM for this so it can be put on a HA cluster. A.) Can a SCVMM cluster be setup with physical machines and B.) Is it possible to setup a SCVMM cluster across two physical locations? If it can be setup across two sites, what DB implications does this cause?
My envisioned setup would be two SCVMM nodes and two DB's, but this may not be technically feasible. I was thinking maybe using Hyper V replica if I do virtualize SCVMM, but I think there are SCVMM implications with this setup as Hyper V replica usually replicates every X minutes instead of seconds and SCVMM config/real time setup gets out of date a little.
