defakto said:Depends. You'd probably be just as happy with a rapto150.
To get the performance of the raptor 150 you're looking at going into the higher end 15k drives, which are significantly more expensive per GB. Add in cost of controller as well because you're going to want a decent controller.
unhappy_mage said:You need a SAS controller to deal with scsi drives. SAS controllers can deal with SATA drives, but not the other way around.
