I'm looking to upgrade my system:
Abit IC7 Max3
P4 3.0C @ 4.0GHz
Radeon 9700 Pro @ > 9800 spds
DVD-RW DL
CD-RW
Antec TrueBlue 480W PSU
WD 120GB HDD (IDE) for storage of files
Removable (External) USB2.0/FIREWIRE WD 250GB HDD (IDE) for mobile storage of files
Now I'm just missing a harddisk for WinXP. As you may know, the motherboard has the onboard capacity to run SATA RAID 0+1.
I'm trying to decide between buying a SCSI Seagate Cheetah 15K.3 (18GB) or a SATA WD Raptor 10K (36GB). I understand that buying a SCSI system will mean that I'll also need a SCSI adaptor, and while I'm unwilling to spend the huge sum of money, I am willing to look around on the forums to find an adaptor.
My question basically is, which should I go for?
I'm not looking to spend that much money on this; for the SATA, I'm thinking I can strike a bargain at ~$75, high maybe $80. For the SCSI, I think I saw a bargain at a similar price, with an adaptor priced at $20.
I must admit that I'm not familiar with either system, so I don't know which is faster. However, I would like to get the faster system: the HDD would be used only to run WinXP. (Which brings up a note: I guess I'll need another regular IDE HDD to run the programs/software).
Please make any suggestions and provide any helpful comments you guys can. Thanks!
- Jason
Abit IC7 Max3
P4 3.0C @ 4.0GHz
DVD-RW DL
CD-RW
- Jason
