20Valver said:What SCSI controller are you using?
Or are you running them on a server?
You'll need a good megaraid controller to take full advantage of them. If your already setup then you should just rock on. They are some of the fastest hd's on the planet.sh0rty said:currently using an ami megaraid and yes I use them as the os on a webserver. I have 6 400gb sata's as the data storage
Why?QHalo said:Do yourself a favor and get rid of them unless you're putting that U320 controller in a 64bit PCI slot.
