Scrolling LED's
Not sure what category this is but i bought this belt buckle awhile back and it worked fine. Then it craped out on me. I think from static. I want to get another one and use it in a mod for my new rig, and was hoping someone here was an electronics genius. Basically i want to be able to control its functions in windows. Probably via a com port. But if that's not possible then maybe some switches mounted else where. If any one wants to take up the task i can send you the broken one for free, and if you can fix it then you can keep it. I can read schematics but have no clue on how to write them. So in return i just need the schematics to do this mod.
-DeleteRadio
