Script to show stats from smartctl for a pool
zfs123
Just something I whipped together to get some information from my new drives. It's basically just a perl reformat of smartctl output:
Code:
root@WKMMG3:~# ./nsdisks.pl mp2
Pool Name: mp2
DISK    VDEV     MODEL               FIRMWARE    PORC    LCC     TEMP
c6t6d0  raidz1-0 HD204UI             1AQ10001    0       49      21
c7t2d0  raidz1-0 WD20EARX-00PASB0    51.0AB51    12      539     23
c6t7d0  raidz1-0 HD204UI             1AQ10001    0       50      22
c7t4d0  raidz1-0 WD20EARX-00PASB0    51.0AB51    161     25599   23
c7t0d0  raidz1-0 ST32000542AS        CC95                        26
c6t4d0  raidz1-1 HD204UI             1AQ10001    0       50      21
c7t7d0  raidz1-1 WD20EARX-00PASB0    51.0AB51    12      521     23
c6t0d0  raidz1-1 HD204UI             1AQ10001    0       52      21
c7t6d0  raidz1-1 WD20EARX-00PASB0    51.0AB51    12      513     23
c6t2d0  raidz1-1 HD204UI             1AQ10001    0       52      22
And here's the code, any comments/suggestions welcome:
Code:
#!/usr/bin/perl
my $pool = shift || die "please specify pool name\n";
my $ZCMD = "/usr/sbin/zpool status $pool";
my $CMD = "/usr/sbin/smartctl -d sat,12 -a /dev/rdsk/";
my @Disk_List = ();
my @result = `$ZCMD 2>&1`;
foreach (@result) {
        chop;
        my $l = $_;
        next if(!($l =~ /^\t/));
        next if($l =~ /^\tNAME/);
        next if($l =~ /^\t${pool}\s/);
        next if(!($l));
        $l =~ s/\t  //;
        $l =~ s/^\s+//;
        $l =~ s/\s+/ /g;
        my ($disk, $status, $read, $write, $chksum) = split('\s', $l);
        if($disk =~ /c[0-9]t[0-9]d[0-9]/) {     # wont work with ctd's higher than 9
                $l = "$vdev" . "_" . "$disk";
                push(@Disk_List, $l);
        else {
                $vdev = $disk;
print "Pool Name: $pool\n";
printf("%-8s%-9s%-20s%-12s%-8s%-8s%s\n", "DISK", "VDEV", "MODEL", "FIRMWARE", "PORC", "LCC", "TEMP");
print "============================================================================\n";
foreach $line (@Disk_List) {
  my ($vdev, $disk) = split('_', $line);
  #my $porc, $temp, $lcc, $firm, $model = "";
  my $porc = "";
  my $temp = "";
  my $lcc = "";
  my $firm = "";
  my $model = "";
  my $tcmd = "$CMD" . "$disk";
  my @result = `$tcmd 2>&1`;
  printf("%-8s%-9s", $disk, $vdev);
  foreach (@result) {
        chop;
        $l = $_;
        $l =~ s/^\s+//;
        my @arr = split /\s+/, $l;
        if($l =~ /Firmware Version/) {
                my $fw = $l;
                $fw =~ s/^.*\s+//;
                $firm = $fw;
        elsif($l =~ /Device Model/) {
                my $fw = $l;
                $fw =~ s/^.*\s+//;
                $model = $fw;
        elsif($l =~ /Power-Off_Retract_Count/) {
                $porc = $arr[9];
        elsif($l =~ /Load_Cycle_Count/) {
                $lcc = $arr[9];
        elsif($l =~ /Temperature_Celsius/) {
                $temp = $arr[9];
  printf("%-20s", $model);
  printf("%-12s", $firm);
  printf("%-8s", $porc);
  printf("%-8s", $lcc);
  printf("%-8s", $temp);
  print "\n";
