ok, zfs and ecc would solve all your problems?
No. And if you ask the same question a third time, the answer will still be no.
Earlier, I asked about if ECC would solve your concerns, and you said no. Now I asked about ECC + ZFS, and you said no.No. And if you ask the same question a third time, the answer will still be no.
How about you explain a bit more, I dont really understand what is so obvious to you?
What is wrong with you? I already said it was obvious, and yet you demanded that I explain the obvious. And then you insult me.
How about you explain a bit more, I dont really understand what is so obvious to you? If you explain, then we dont have to ask a lot about this thing, that is so obvious to you, but to no one else?
Really? Is this what JoeComp means? No, I think you have misunderstood him because that would be really weird. The reason I dont understand JoeComp, and kept asking again and again, is because that such a request would be just too strange, let me see if I understand your interpretation of JoeComp's posts correctly:What he's saying is that if you have a server running ZFS, with ECC memory, you can still put corrupt data on it in the first place. Essentially, ZFS with ECC memory on hardware that isnt broken can ensure that you get back exactly what you wrote. The issue remains with writing bad data in the first place. Now if you say, "I know the data started out as good" then with ZFS it will stay the same so long as it stays solely on the ZFS box. For example, if you have a windows box putting data onto the ZFS box, and manipulating the data on that box then those actions could introduce errors that ZFS would not consider errors, and thus circumvent the ZFS checksums and ECC memory protection.
ZFS does that. But other than that, I dont know how good tripwire or anything else works. But snapraid(?) is claimed to have a solution similar to ZFS?As far as the OP's question goes, what you would want is some sort of hash of the file at the beginning, an 'initial hash' and then some mechanism to periodically check the actual hash against the initial hash. You'd probably need to roll your own solution to get something like that. I don't know of anything off the top of my head that does that.
<=- Looks at my phone... I thought it was Monday today![]()
Yes, ZFS supports this. It is called Snapshot. You can roll back to earlier states. If your zpool becomes corrupt, you can rollback to an earlier state. If that state is also corrupt, you can rollback to an even earlier state, etc. You use "zpool import -F"^^
as I posted for tripwire. this tools is remarkable helpful for checking the delta( not the file only. the rights aka drwxl, system changes), where very useful troubleshooting "hijacked" system or unstable system after the major update
tripwire can revert back to previous state (files, system changes,libraries, and many others)
does this zfs support?just throwing an Idea...
as I know, non built-in "tripwire" tools in any filesystem.
"JoeComp claims that if the data that ZFS gets, is already corrupted, then ZFS can not fix such errors?"
Such a request would be just stupid, and I doubt your interpretation. I mean, how in earth could any filesystem repair already corrupt data?
For a filesystem to repair, say C++ files, it has to have knowledge of C++, it must have an C++ compiler built in, to be able to debug C++ source files and correct it automatically. But say that the C++ file has a corruption where a line is lost. How can the filesystem know if the line should be "color the window black", or "color the window white" or which color? For this to be possible, the built in C++ compiler, must be able to read minds, it has to have psychic powers, otherwise the filesystem can never figure out which color the window was meant to have. Say that several C++ files are heavily corrupted, then the filesystem must use its psychich powers to be read the minds of the developers, and restore the corruption.
And if the filesystem needs to be able to repair corrupt Photoshop data file, the filesystem must have Photoshop built in, with psychich powers. And the filesystem should have all different versions of Photoshop built in, to restore correct file version.
And the filesystem must have MS office built in, all versions, so he understands MS Office data files and repair those files. And have Diablo3 built in, so he can repair D3 files. etc
The filesystem must have all software ever constructed built in (or a database describing each file) and in addition to that, it must be able to read minds of living developers, and dead developers.
Now, is this is a feasible request of a filesystem? Is this a clever request? Hardly. Such a requester must be IT illiterate or just dumb. This is "obviously" impossible to achieve. Psychic powers? All software ever constructed, built in?
My first interpretation of JoeComp was this too, but no one is that dumb, so I figured out I must have misinterpreted him. And because he will not answer to questions, we will never find out exactly what he meant.
You mis-understood me here, I never said ZFS would fix corrupt data. I said that ZFS would give you back exactly what it was given.
I think you explained the obvious as well as I did. But it did not seem to get the point across, did it? You can see why I stopped trying.
So what is his point? That ECC RAM is a necessary step, to provide data integrity? Yes, everybody knows that nowadays (after the research paper, but that was not obvious some years ago). So basically, JoeComp just reiterated what everybody says? For data integrity, use a filesystem with end-to-end checksums and ECC RAM? Great info, that was news to us here, thanx for enlightening us. That was the obvious part? Why not just write that, instead of confusing people here? The next time we have to communicate with JoeComp, we will ask you, who understands his incomprehensible posts, while noone else does.You mis-understood me here, I never said ZFS would fix corrupt data. I said that ZFS would give you back exactly what it was given. If it was given errors then you will get errors back. ZFS CAN repair files that get corrupt on disk AFTER they have been written (correctly) by ZFS as ZFS includes redundancy. It's not magic. JoeComp's point was that adding ECC memory is only PART of the protection scheme, just like ZFS itself, that's only PART of the protection scheme.
I checked Tripwire site, there was many links. Can you post those interesting scenarios?Nope. Snapshot is a different beast.
Check Tripwire site. You can find. Many interesting scenarios.
Tripwire is more more powerful than snapshot. How about finding out some incompatible s libraries after amjor update. Can snapshot do that?
Can snapshot restores. Certain object files and check dependencies?
tutorial is spreading on the netI checked Tripwire site, there was many links. Can you post those interesting scenarios?
Is that the point? Stupid. No solution on earth can always guarantee data safety, no matter if you pour in billions of USD worth of research. You can almost never guarantee anything:No, the point was that using ZFS, EVEN WITH ECC, can not always guarantee data safety.
I dont see those interesting scenarios? Do you have a link to them?tutorial is spreading on the net
start with http://www.tripwire.org/, a
you will be given 3 selections. pick on tripwire open source selection that links to http://sourceforge.net/projects/tripwire/
the last 2 selections are commercial products with GUI, enhancement and supports
open source GPL tripwire is a CLI only as I know, and users/forums/mailinglists support only![]()
"You can lead a man to knowledge, but you can't make him think."I think you explained the obvious as well as I did. But it did not seem to get the point across, did it? You can see why I stopped trying.
I dont feel that way. It IS stupid. No one can guarantee anything. Period. If you believe something else, I suggest you go to university and learn something.If you feel that way,
I am saying it is stupid to believe that any filesystem can guarantee data integrity. That is unrealistic. Do you agree on this? Or do you believe any storage solution on earth, can guarantee data integrity?If you say it is stupid for you to bring up "end to end checksums" in this thread, then why did you do it?
Yes, I went to your linkI give you a starting point and can not give you everything that you want.
I just thrown some examples on my previous posting
you have to read!...
the information is on the net.
Does anybody know the best way to check data integrity on Linux? In my situation, I need to keep approximately 12TB of data constantly online (4x3TB). The system will be JBOD since each 3TB disk holds static data that is backed up offline on another 3TB disk.
Is there a way in Linux to periodically scan all 12TB of data to check for data integrity? I would like to make sure that all bytes are still readable and if one file is unreadable, to give a warning message so I can delete the bad file and replace it with a copy from backup.
I'm concerned about sectors going bad and individual files within the 12TB slowly going bad and becoming inaccessible when they are requested.
Also, don't suggest things like XFS, etc. I need maximum compatibility, so Centos 6 with ext4.
