Screws mounted correctly?
Deschain
I just mounted my abit mobo today and i want to know if they are okay like this. They are a little mis-aligned (the only way it would go in, i couldnt shift it) with the center part of the screw hole and im wondering if they will cause any electrical problems. Heres a pic:
Looks fine, they're not always perfectly centered. It won't cause any problems like that.
