screws for motherboard?
nappa
Hey everyone I was wondering where on newegg I could get screws and other things neccesary to install a motherboard? Will it come with the motherboard or does it come with a case? If it comes with the case is there a way to buy them sepperate I cant find them anywhere on newegg. Thanks
-Nappa
They should come with the case. If not your local store should have them. If not ask you buddies, they will proably have some extra.
compusa and microcenter sells them, but i didnt see anything on best buy about them.
you can get the machine screws that bolt down pci and agp cards at a hardware store, but the gold riser screws that screw into the case and seat the mobo i think are a specialty item that you won't find at most hardware stores. a kit of these screws came with eveyr case ive bought, albeit never enough riser screws to hit every hole on the mobo :(
