Screws for Motherboard
tel0004
I'm building a computer right now, and I am missing the screws for the motherboard. Not the standoffs, but the screws that you use to attach the motherboard to the standoffs.
Should those have been included with the motherboard, or with the case? The only reason I think it could be the case is because the case includes the standoffs.
Do you guys think this is a part a computer store like microcenter would have. I really don't want to wait a week for them to be shipped to me if they were not included.
Thanks.
I'm sure you can get some at Microcenter... if they don't have them on the shelf, ask somebody in the service department.
The screws ought to have come with the case - as you say, that's what comes with the standoffs they're supposed to screw into. Make sure you match the screws to the standoffs if you're buying them, they do come in varying types. Best to take one along and check they screw in properly.
should come with the case but any half-decent PC shop should have them.
Ok, I found them. I have a coolermaster CM 690. They are all screwed in on the side of the case. Its kind of a good idea, since they are always around when you need them, but it was confusing, since they are on the bottom of the motherboard tray.
Thanks for the help.
OMFG
RTFM
I got so sick of reading about people being pissed at the 690 on newegg because it 'didn't come with the mobo screws' >>>so it didn't come with mobo screws, ok, I'll just use my old standoffs >>>
then we I got the case >>>
The first thing I though of when I saw all of the screws, obviously holding NOTHING in place, screwed to the back of the 5.25" cage was "strange, I wonder what those are" *refer to manual*
omgomgomg
/rant
delete if you want....but i couldn't stop myself from typing it
phew...:(
