PornoSatan
- Sep 3, 2004
I bought a Viewsonic A90f+ 19" a while back and had it working fine.. until I moved. Ever since I've moved there hasnt been a refresh rate or resolution that hasnt annoyed the shit out of my eyes. At 1024x768 at a refresh rate of 75hz the screen shakes real violently and would most definately cause some eye problems if looked at for too long. 85hz is far less so but still an eye strainer and (I think) is whats causing my current eye problems. I would go above 85hz but my normal display is running at 1280x960, which is the max refresh/res combination I was happy with, 1024x768 is just too small for normal desktop operation on such a large screen. Oddly enough 60 hz has the least amount of shaking but ofcourse has that annoying "flicker" to it.
Its far more noticable and prevailent when TV's are on and such. I've done a test where I turn the contrast all the way down and the brightness about halfway to display moire patterns, and if I try reducing the moire patterns the entire screen starts to shake even more. I think it might be a power issue but im not entirely sure. Tips//help?
Just to add, there's nothing close to it that could cause interference, the TV is across the room, and not much else close to it except a lamp at adequate distance, and then all the typical crap, modem, router etc.
