Mar 17, 2022 #1 C colore Limp Gawd Joined Sep 18, 2010 Messages 419 Hello Is there a device to plug in my laptop's HDMI and record the video/sound without interrupting the laptop's display? Thanks
Mar 17, 2022 #2 pendragon1 Cat Can't Scratch It 2FA Joined Oct 7, 2000 Messages 79,931 setup another system/device with hdmi video capture and then just mirror the laptops display through settings.
Mar 18, 2022 #3 Krispy Kritter Gawd 2FA Joined Feb 13, 2003 Messages 712 Assuming you aren't trying to capture media playback, you could use the HDMI output as noted above. You could also likely use a screen capture utility. I haven't used any in many years and I wasn't concerned with audio, but that could be an option.
