screen flickers and then comp freezes
ok on the last 2 boots (which I could only achieve after unplugging the power cord to successfully shutdown) - the screen flickers and the computer freezes. Have latest bios and drivers for everything.
WTF is going on - I have have been dorking around with this build for 3 weeks now and it still won't run stable. getting ready to throw it out the window!!
1 Intel Q9450
1 EVGA 132-CK-NF79-A1 LGA 775 NVIDIA nForce 790i Ultra SLI DDR3 ATX Intel Motherboard - Retail
1 G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL7D-4GBHZ - Retail
1 Logitech G15 2-Tone USB Wired Standard Gaming Keyboard - Retail
1 Logitech G9 Black 5 Buttons Tilt Wheel USB Wired Laser Gaming Mouse - Retail
1 Microsoft Windows Vista 64-Bit Ultimate for System Builders Single Pack DVD - OEM
2 EVGA 512-P3-N871-AR GeForce 9800 GTX(G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
2 SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
2 SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive (Raid 1 – data only)
2 Western Digital Raptor X WD1500AHFD 150GB 10000 RPM SATA 1.5Gb/s Hard Drive (Raid 0 – OS/programs)
1 Coolermaster 850 Realpower pro (to be replaced with PC Power & Cooling Turbocool 1200 tomorrow)
Overclock too much? Is everything in to BIOS set to stock? what have you tweaked?
is the HSF seated correctly? after the machine locks up... restart it right away and check the temps in the bios.
Have not overclocked yet (still trying t get stable) - bios is default.
Just installed a IFX-14 and temps are fine.
I have a batch of Thinkpads that do the same thing - screen flickers, machine freezes. Turns out it's the heatsink for the video chip popping loose. I'd check your vidcard.
haven't taken the 9800gtxs out, but I also received this message "Display driver nvlddmkm stopped responding and has successfully recovered."
Any ideas. Running the new nvidia beta drivers. (had this with old 174.174 drivers as well)
Well I seem to be ok right now - I did a system restore to prior to the beta drivers. Took out the 9800gtxs and looked them over - they looked fine but are basically encased in plastic. Reset the bios.
Played Oblivion for several hours and it didn't crash. We will wait and see what happens.
