Screen Flickering with Nvidia Drivers
I have the newest nvidia drivers that came out yesterday. However, this is an issue i have had in the past and have never been able to solve it. Sometimes as i am scrolling down a page my screen will flicker once or twice really fast. It is random when it does it. I have tried updating and removing drivers but it does not fix anything. However, when i load up with the default windows drivers it does not happen. I believe it has something to do with direct x but updating it did not fix my problem either. my specs are in my sig and i have windows vista x64. i appreciate any help
thanks for your time
Try reverting back to the previous driver you were using to see if the problem goes away.
Try enabling VSync and/or change the refresh rate to 60Hz if using an LCD.
