Here is the screen, what is causing this. It only happens when I wake my computer out of "sleep" mode. If I reboot it goes away so I have a solution, but it is still annoying.
Make sure you have the latest chipset drivers. Try relocking your videocard pipes that you unlocked this type of thing is common when you unlock bad pipes. That might not be it but try and see if that is the problem.
