Screen display error
dominoman
I have a 1 year old Dell Latitude laptop and there is a problem with the display. One or two pixels seem to be permanently white, so that it looks like there is a mark on the screen. Its only small but has started to get annoying. Is there any way of fixing this, or do I just put up with it?
Thanks for any help.
My guess is, you are stuck two ways, pixels and having to live with it. It happens, learn not to stare at that spot if you can. Its unlikely Dell will replace at this point. On the other hand, they do have an 800 number.
Luck
