Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
is this the same thing that you can use for glasses and sunglasses and stuff?
just some liquid that you apply over? i wouldn't put too much faith in them.
Most scratch removal products will destroy the anti-glare coating on LCD panels, which means instead of a scratch you'll have a very shiny area on the LCD panel. Not a worthy tradeoff, IMHO.
I had these things that looked like little scratches on my laptop's LCD. I bought some Kensington Surface Guardian lint free wipes and screen cleaner.
I sprayed some of the solution on the wipes and carefully wiped the sceen down, did it a couple of times and now the "scratches" appear to have dissappeared.
Might be worth a shot if that's all you are dealing with on your screen.
