E.E.L. Ambiense
- Jun 13, 2008
Here I am again to start off the new year with a new build. But it's not going to be huge. Not this time. I love large full-towers full of 800 lbs. of liquids and heat-producing hardware, sure, but I've decided to go the exact opposite direction. I've always wanted to build something small; like really small. I just never got around to it. And I was waiting for the hardware to get up to snuff for what I wanted to do with this vaporous idea of a build that had been bouncing around in the noggin. I think it's finally here. And a few of my piers on Bit-Tech have repeatedly stated for me to do a scratch-build, so I'm relenting. I'm throwing caution to the reckless wind. I'm just going to see what happens. This will be a HTPC build. And I've been hard at work on it already. Hell, I even scratch-designed a quasi-Blu-Ray font for the build's name because I'm anal.
Anyways, I present to you my first 'scratch-build' project.
I'm going to be designing and cutting this thing out of different kinds of acrylic. Namely, transparent blue, solid black, and a cool mirror-blue acrylic for accents I've been itching to try. I may change things; I may not. Just have to see how it goes, ya know?
This build will comprise a few familiar parts. Namely, the motherboard. Bit-Tech was kind enough to review this board and what they found really perked my ears up (and eyes, if that's possible). Finally, a board that can get desktop performance out of a mini-ITX board, and fullHD playback too.
System Specs (subject to change since it's not totally set in stone yet):
Motherboard: J&W® Minix mini-ITX 780G AMD board
CPU: AMD X2 5050e 45w AM2
RAM: GSkill DDR2-800 4gb SO-DIMM kit
HDD: Western Digital Scorpio Black 320GB 2.5" SATA II
Optical: LG GGC-H20LK Blu-Ray Disc / HD DVD / DVD combo unit SATA
OS: not decided on yet, but probably Vista Home Premium 32-bit
PSU: not decided on yet, but I have an idea
Let's get started, shall we?
Here's a concept of what I'm going to build...
It's been interesting, to say the least. I've probably revised things with this build design over 17 times at this point. :hehe: I keep going tiny, then I expand it back out because I want more airflow, then I shrink it back down because of size. I've had designs with fullsize PSU's in it; others with 5 HDDs in it; even one with it on water with a custom chipset block, etc. I just realized I wanted to keep it simple and easy to maintain. As well as reasonably efficient, but mostly QUIET.
While I'm working on finalizing intricacies with the design, I'll start with some of the actual hardware.
Here's the motherboard. Bit-Tech was right; neat packaging!
Here's a CD-R on top of the box for size comparison. It takes a bit getting used to looking at, I know.
Here's some more of the junk-- er, stuff going in the build...
HDD chosen....
Let's have a closer look at the chipset on the board. Hmm... I'm curious as to why this thing seems to cook so bad.
Let's pop the stock sink off and have a look, shall we?
...I really hate this stuff. Frackin' dried-bubblegum-under-the-lunch-table-at-a-filthy-elementary-school-style TIM... ugh.... It's
After a quick cleaning with some TIM cleaning solution, this should make it a bit better.
And a little bit of some Céramique...
And pop the sink back on. I haven't been able to check on temps because I haven't actually run electricity through it at this point, but later on I was able to check power at the wall. Seems like the system under OS install was hitting 141w according to my Back-UPS. I don't think it's that high, TBH. Have to think I only have one HDD, and it's a 2.5". As well as one optical unit, 45w CPU and I'm not OCing or anything of that sort, and two 120mm low-power fans. Anyways, after I got into BIOS and let it sit for a while, BIOS was reporting that the NB was running around 52-degrees with a fan gently blowing over it. That seems consistent with others who have this board, but I haven't been able to flex the system's muscles just yet, so I really have no idea, lol. You're stressing me out, stop asking!
Installing the RAM... angle insert...click!
Let's install the CPU...
And some TIM of choice...
There we go. All done.
Here's the CPU cooler I've tentatively chosen. The Silverstone SST-NT07-AM2 1U cooler for up to 65w CPUs. Seemed to fit the bill fine what I need.
Fitting on top of board to see if I have any clearance issues. Everything looks fine. Looks like it'll fit like a glove in there. I'm thinking of tossing the stock fan also for a thicker 25mm 80mm fan. I'll get to that later on though.
Until the next update, I got nuthin'. :thumb:
