Scrambled Settings Any One?
abledon
Can anyone help me with getting my speeds up to or close to effective clock rates as seen below? MY CPU is AMD AthlonXP 3000+. The settings below are provided by AIDA32 and are default values after resetting the CMOS. If my system can run at 200Mhz ( current default setting ) I would assume it should run at 200Mhz all the time with the proper CPU speed. But if I change the BIOS to 200 FSB or change Clock frequency or Muliplier settings I have no video. Any serious help would be appreciated. All hardware and OS files and drivers are current and up to date as of this post.
Motherboard ID 04/17/2003-KT400-8235-6A6LYS29C-00
Motherboard Name Soyo KT400 DRAGON Ultra Platinum Edition
CPU Type AMD Athlon XP-A, 1300 MHz (6.5 x 200) 1700+
CPU Alias Barton
CPU Stepping A2
L1 Code Cache 64 KB
L1 Data Cache 64 KB
L2 Cache 512 KB (On-Die, Full-Speed)
CPU Physical Info
Package Type 453 Pin PGA
Package Size 4.95 cm x 4.95 cm
Transistors 54.3 million
Process Technology 6Mi, 0.13 um, CMOS, Cu
Die Size 101 mm2
Core Voltage 1.65 V
I/O Voltage 1.6 V
BIOS Type Award
Award BIOS Type Phoenix-Award BIOS v6.00PG
Award BIOS Message K7VX4-2AA7
System BIOS Date 04/17/03
Video BIOS Date 11/18/03
Front Side Bus Properties
Bus Width 64-bit
Real Clock 100 MHz (DDR)
Effective Clock 200 MHz
Bandwidth 1600 MB/s
Video
Memory Bus Properties
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 167 MHz (DDR)
Effective Clock 333 MHz
Bandwidth 2667 MB/s
Graphics Processor Properties
Video Adapter nVIDIA GeForce4 MX 4000
GPU Code Name NV18B
PCI Device 10DE / 0185
Transistors 29 million
Process Technology 0.15u
Bus Type AGP
Memory Size 128 MB
GPU Clock 274 MHz
RAMDAC Clock 350 MHz
Pixel Pipelines 2
TMU Per Pipeline 2
Vertex Shaders Not Supported
Pixel Shaders 1 (v0.5)
DirectX Hardware Support DirectX v7.0
Pixel Fillrate 548 MPixel/s
Texel Fillrate 1096 MTexel/s
Bus Type DDR
Bus Width 64-bit
Real Clock 202 MHz (DDR)
Effective Clock 405 MHz
Bandwidth 3240 MB/s
I'm thinking your agp/pci slots aren't locked. I kinda doubt with that old of a system that you will have that option in your bios. Not sure how to get around this but I'm pretty sure that's your problem.
What would make the system old? SInce I just put it together not a month ago. Just curios.
