SCOUT VS. LANCOOL
I have the Scout. It's a great case. But if you ever decide to go to water cooling, then the lian li would be the way to go cause you can put a dual rad in it. Can't with the Scout. Other then that, there pretty much the same. Just comes down to looks. Oh, and you can't mount fans on the side window on the Lian Li. You can on the Scout.
Another vote to the LanCool PC-K62.
I used a lancool case on a recent build and liked enough that I'd consider using/reccomending lancool cases for future builds. For the record I used the PC-K7B. The fit and finish was VERY good for a case at it's price point.
Coolermaster is decent but if you can get a lian li for a similar price there is no contest, lian li wins.
