Cubism Dream
- Mar 28, 2012
Has anyone tried one of their amps and if so how does it sound?
Jason Stoddard said:Bingo. There's no universal solution. Except our upcoming amp Mjolnir, which we'll have information on in a few days--but it will require re-termination of every single one of your headphones, since it's a balanced amp--and balanced only. And it's $750.
NwAvGuy himself classifies Schiit as one of the FOTM companies that puts a bunch of cool-sounding parts inside the same box, unfortunately with shady engineering.
This is completely wrong as far as I know. NwAvGuy got banned from Head-Fi over a discussion on the Schiit Asgard and it's DC power down transient but he has never tested nor listened to any Schiit products as far as I know.
Beyond that, Schiit eventually stepped up and addressed the problem and NwAvGuy states so on his site.
I have heard only good things.
The only thing to address is objective measurements. Anyone who tells you that you can't measure sound is either lying, or deluding themselves. It isn't magic, it is electrical engineering. For something to be worth paying for over something else it needs to measure better in some way. There's no point in paying for voodoo.
In the case of a headphone amp what you want is low output impedance (most important if you are using low impedance phones, but there are a lot of real popular low impedance phones), low noise, flat frequency response, and low distortion. If an amp can't do better in those regards, and really the output impedance, noise and distortion are the big ones, a flat FR in the audio range is trivial, then you aren't gaining anything audibly.
You really don't want tubes. Tubes are not as good as transistors for audio reproduction. They just aren't. They don't do as well for any of those things in a well designed circuit. While you can make a tube amp that measures pretty good, you can make a transistor amp that measures better for less. There's a reason they are pretty much only in the audiophile voodoo market. Where tubes are used today is when their distortion is desirable. Like guitar amps. Even a clean electric guitar has a good bit of distortion to its original signal. A completely dry electric guitar sounds like crap. Well tubes, when driven in to their non-linear region give really sweet guitar sound. Hence they are used for the very reason that they distort the audio.
Also getting banned from headfi isn't something I would see as a mark of shame, particularly. They have a LOT of audio voodoo people on there. I used to hang out there but I got really tired of all the bullshit arguments that more or less came down to "I spent a lot of money on my gear so I feel the need to believe it is better than everything else, without any evidence."
If you are thinking of spending that much money either buy the Objective2 or wait until NwAvGuy releases the ODAC and buy the O2 + ODAC combo. At least these products have measurably-excellent sound quality that isn't based on brand names and FOTM chips. NwAvGuy himself classifies Schiit as one of the FOTM companies that puts a bunch of cool-sounding parts inside the same box, unfortunately with shady engineering.
EDIT: change measurably-excellent to transparent in the above post. The sound of the O2 is not something you compare other devices to, it is the benchmark. Its sound quality is imperceptible to that of the Benchmark DAC1 PRE ($1400 studio quality interface).
Schiit makes very good products, and if you have an issue their customer service is excellent. That being said, I've built two O2 amps and have the parts for a third. I'm nothing but happy with the amp, and if you're not into building your own JDS Labs should be your first choice imo. John at JDS has excellent customer service and will treat you right.
So jelly![]()
Going to have to disagree with the Objective 2 being the "benchmark" reference amplifier. The high end electrostatics (Blue Hawaii), outclass it in every way possible.
EDIT: changed definitive to benchmark
Build one! It's cheap and easy. I'm not exactly a soldering expert. I built each of mine for just under $100 total including shipping.
NwAvGuy engineered his amp to measure as well as the Becmark DAC1 does, and hes done a good job of achieving that. So you will be able to buy a amp for ~$150 that measures 99.99% as well as the Benchmark does. In my mind this clearly qualifies the amp as the "benchmark" reference.
[]http://img684.imageshack.us/img684/3315/dcfn00022.jpg[/]
[]http://img846.imageshack.us/img846/5125/dcfn0006.jpg[/]
Well you have to remember it's a Benchmark DAC, not a Benchmark amp. The amp in the Benchmark DAC 1 isn't a benchmark headphone amp imo, just a very good/excellent one.
Any chance you could list where you sourced the parts from?
So is the general consensus that the quality of the sound is all relative?
You'll never get a consensus. Different people have different opinions. My opinion is that what you like in terms of sound is what matters most BUT I think expensive headphone amps are a waste. If you like something like recessed mids, just use a digital parametric EQ to get it cheaper, rather than getting an amp that has problems.
Ultimately you only need to make yourself happy. I'd just try and do it is economically as feasible. I wouldn't go and buy something expensive if there is a cheaper way to get the same thing.
However others will disagree with me. You won't get a consensus.
If I have to pick out the differences individually and its not blatantly apparent , then I've spent too much.
