Sceptre X37sv-Naga 37"
I was going to purchase a Dell 2405FPW, but I held out because of the rumored 2407 and in the mean time I have been researching other monitors. I came across this one and have done extensive research on it. Essentially, it is exactly what I want.
However, after reading the avsforums and these and several other, there seems to be a "judder" bug in version 2 of this monitor that is prevalent in all of them. I have read that there is a firmware fix for this issue, but no matter how hard I look I can't seem to find what it is or where I can get it or if it really is even true that there is one.
I decided to go directly to the source, so I contacted sceptre through email. Here it is:
I wrote:
I am highly considering purchasing this monitor from costco.com this weekend. I have done extensive research on this product and I have found that there is a "judder" bug in version 2 of the monitor. I also read that there is now a firmware fix for this issue. Is this true? If so, where, how, and what will I need to do to get it fixed. I need an answer to this fast as I am about to purchase it.
He replied:
Dear Customer,
If you're about to buy it. Test it on a computer when you it arrives.
If it has the judder problem we can call tag the tv to have it
serviced.
Best Regards,
Sceptre Technical Support Group
I really don't know what he is talking about. He is evading the f-ing question and I don't like it. What does it mean when he says "we can call tag the tv to have it serviced"? Is it just me, or does that make any sense?
I am sure some of you guys have experienced this issue or might know where I could find more information regarding this. Any help on this would be very much appreciated. If there is a fix for it I will definitely be buying it this weekend from costco.com
Here is the link if you want to check it out:
http://www.costco.com/Browse/Product.aspx?Prodid=11042448&whse=BC&topnav=&browse=
In the AVS Forum thread, you'll see that Sceptre has said that any X37SV purchased through Costco will not have the firmware fix applied, and therefore will have the jutter bug.
The issuing a call tag means that they'll arrange to have the TV shipped back to them to be fixed; I think the latest reports are that they pay shipping both ways.
The firmware fix can only be applied at the factory, which is why you have to send it back to them (and they can't just supply you with a file to flash).
My experience? Well, I just got my X37SV on Wednesday, and it has the jutter bug and also has a 1:1 mapping problem over DVI, though people are suggesting that it could be my video card. I'm still playing around with that (the 1:1, not the jutter, which is a fault of the monitor for sure). Running over VGA works at 1920x1080 and fills the panel, but...it's VGA. I want my digital connection.
Also, I should point out that the jutter bug can be "fixed" by setting your refresh rate to 53.307 Hz in Powerstrip (you might be able to do it directly in drivers if you're using an Nvidia card). I'm not a big fan of this, so after the Super Bowl I'll contact Sceptre about getting one of those call tags. I can update this thread with new info as I go through the process, if you'd like.
Wow this sounds like a pain. Can't you guys get units that already have the flash fix?
Thank you so much truffle00! That would be awsome if you could keep me updated as you go through the process. I would appreciate that alot. I also don't like the idea of having to change the refresh rate either.
I wish that somehow something could be arranged so that they do the firmware fix at the factory and then once it was fixed costco would ship it out. That is horrible knowing that the monitor you ordered is going to have the jutter problem without a doubt and then have the damn thing shipped to sceptre and then shipped back. What a pain in the f-ing ass!
I really really want this monitor, but jeez, I don't know if it is worth it. Oh man do I want it bad, but AHHHHH what should I do... this is so frustrating.
Responding to Riptide_NVN: I sure wish there was a way. There definitely should be!
The only reason I am bothering with this display is:
1) costco is selling it or I wouldn't even consider it (because of amazing return policy)
2) It has a plethora of inputs
* HDMI/ DVI Support HDCP
* HD Component (Y, Pb, Pr): x 1
* S-Video 4-pin DIN: x 2
* Composite RCA A/V: x 2
* RGB 15-pin D-Sub: x 1
3) I have done extensive research on it and most people are very pleased with it (version 1 didn't have this "jutter" problem.)
4) It has built in NTSC & ATSC tuners
5) It supports HDTV 1080p, 1080i, 720p, 480p, 480i (ATSC + NTSC)
6) Its resolution is 1920 x 1080 so it will be sweet for computer use
7) It is a perfect size for me (37")
If Costco had the 37" Westinghouse then I would probably opt for it, but they don't. I have been saving this money for a very long period of time and I would not spend that kind of money on something that wasn't from Costco. Just knowing I can return it whenever I want for any reason is such a great feeling. One that I can't have with other stores.
Hey truffle00 or anyone else that might be able to answer this question. I was wondering if I will even be able to change the refresh rate to 53.307 in Powerstrip or using my Nvidia drivers.
The reason I ask is because I will be using my laptop and I thought there was no way for the refresh rate to go below 60hz on it. My laptop has a 7800 Go GTX (which I don't know if Powerstrip supports mobile cards). Also, the Sceptre will be primarily used by being hooked up to my laptop. I don't even own a desktop.
I sure hope this can be done because if not, I don't think I will be buying it (what a shame too, just because of some stupid mistake they made. If only they would have not done the revision and left it at version 1, we wouldn't be in this predicament)
Powerstrip should still work...and it is shareware, so you should be able to try it out before you buy.
And I think there are some things that are better with the v2, so it wasn't a complete waste...better HDMI port or something.
I have a question about Powerstrip (and it did seem to recognize my 7800 Go GTX). I downloaded the program just to see what would be involved in changing the refresh rate to 53.307hz and I begin to click on the down arrow on the refresh rate tab and once it got below 59.7hz or so my laptop screen was shaking with black horizontal lines and I had to exit. I was afraid it might damage my screen. Is this normal? How should I approach changing the refresh rate without hurting anything? Sorry for all the questions and being paranoid, but I spent a heck of a lot of $$ on my laptop.
Another question. Since you say changing the refresh rate to 53.307hz on the video card will take care of the "judder" problem, does that mean that the Sceptre is only affected by this "judder" bug when connected to a PC? So, if I were to connect a standalone DVD player or watch Standard TV or OTA HD it wouldn't have this problem?
I re-read nearly the whole entire avsforum thread on the monitor and I am still a little confused. I appreciate all your effort in helping me truffle. You rock :cool:
LOL well I might rock, but apparently not enough...I don't remember what was said about judder on the other sources. I *think* <== key word there I remember reading about how it was there, but there's an upside: you can't really notice it on things like most video. For most video, you don't have something moving at a fast, steady rate across the screen, so you don't see when its motion is interrupted by judder. I've watched video on my computer at 60 Hz, and it tends not to bother me. I imagine it would be more of an issue with something like sports, where you might have a guy running across the screen (or the guy centered with the background panning, which you'd probably notice less). However, it is hell in things like games. It's the equivalent of getting 3 fps...the guy skips across the screen. You'll be watching an open doorway, and the enemy will just appear in it, and since you didn't see him moving across it he'll have the edge and will kill you. Or you'll be playing your golf game, and the swing meter jumps across the bar in intervals, making it really tough to get a good shot.
On Powerstrip...I don't think you'll hurt your monitor by underdriving it. I imagine overdriving it would be more of an issue. I've noticed the same thing you're talking about, and it did worry me, but setting it straight to 53.307 Hz gave me a steady image. Prior to seeing the whole number, I saw where people said to set it to 53.3 Hz, and that gave me a wobbly image as well, but 53.307 was perfect. There's no reason to not just go straight to that.
Thanks for the VERY informative reply! I suppose that is good news that it only really happens in games... and not everything else, hehe. I have a problem with Powerstrip. It is fricking bizarre. I go into display profiles > configure > advanced timings > and right under where it says "vertical geometry", where it says refresh rate... I changed that to 53.307hz and the strangest thing happens. Once I change it and accept it, it automatically changes to 53.295. I have tried several dozen times and everytime it changes to 53.295 and at it is quite shaky. I have no clue why it won't stick at 53.307. Somehow, I accidently stumbled across 53.61 and that worked almost perfectly. I wonder if that would be acceptable to have it at 53.61. It just pisses me off that for some reason I can't get it to stay at 53.307. I must be doing something wrong. Any ideas on why the heck this is happening?
truffle00 said:
Well, the Sceptre has the ATSC and NTSC tuners, and has a lower response time. Define "better". :p
Color and brightness quality ! contrast !
I can upgrade the firmware for myself ?
Maybe uncheck "Lock total geometry" and "Lock scan frequencies" if those are checked?
Well, I don't have the Westinghouse in my home, so I can't go by anything other than the manufacturer reported specs, but they are apparently equal in contrast and the Sceptre edges out the Westinghouse in brightness (600 cd/m^2 vs. 550).
The Westinghouse also has 2 DVI ports and 2 component inputs, vs. the Sceptre's 1 HDMI and 1 component.
And no, you cannot update the firmware yourself on the Sceptre...I don't know if you can or if there is an issue on the Westinghouse.
They were unchecked and I tried again just to make sure, it doesn't work. This is so damn strange. LOL, I can't even change it to the right "hz" to fix it. This sucks : (
I wonder if yours might be changing to 53.295, but somehow not effecting anything... IDK... this is just too damn freaky
I really do wonder if it would be ok at 53.61... I mean it is relatively close to 53.307... even if it does though, I still want to figure out why it won't stay at 53.307. I am close to just giving up on buying this monitor, but I can't just give up. I can't, I say... must research more... and hope truffle responds... :p
Sorry, I don't know Powerstrip well enough to help you troubleshoot past that. Maybe you should make a new thread about Powerstrip? Maybe try unchecking any of the Synchronization boxes if they're checked? Basically, uncheck anything that looks like it might lock something in.
Also, what mattters isn't how your laptop's LCD handles the 53 Hz refresh rate but how the Sceptre does, and that might not be something you can try out unless you have it. I don't think that 53.307 Hz was calculated but just where people found that the monitor didn't have judder and also didn't have any weird scanning artifacts (wavy pixels, etc.) If 53.6 Hz works for you on the Sceptre, then by all means stick with it.
