The Sceptre 24" is a great display but I have a question about using an HDMI to DVI adapter to achieve 1080p. In my case whether coming from my camcorder or my cable box via HDMI/DVI I don't get full 1080p or 1080i signal. Also the manual says changing formats between 16:10, or 16:9 or 4:3 can only be done using the VGA port. I will assume then... that full 1080 support will be an analog YCbCr solution using the VGA port.
Does anyone know for a fact one way or the other?
CMoore
CMoore
