swatbat
- Apr 25, 2001
Yea this could be interesting.
Arcygenical said:2 questions.
Did the drive have a microfilter in it? Or was it mounted directly onto the flipside of the old drive cover, glued on around the hole?
What's the pink thing in your pic
This is gonna be awesome. You should sell DD the rights to do this or something... if it works![]()
ChingChang said:impressive
and the hard drive being on the carpet like that won't do anything, the metal case acts as shielding.
yes, but the ESD sensitive components were raised above the ground, not touching the carpet. And those components don't contact the metal casing on the outside. There is something between that, usually either plastic or foam.SarverSystems said:Except for the fact that the ESD sensitive components are on the bottom of the drive, on the outside of the metal enclosure, which by the way, no longer completely surrounds the innards of the drive. Even with the metal cover still on, there are lots of connections between the inside of the drive to the outside, hence, allowing any ESD to travel from the outside of the drive to the inside.
Too bad NCQ really slows down that read/write arm eh?
