I can't get my canon D1250U2f scanner to install in win 7 x 86 even using compatibility mode. Apparently, scanners are going to be the red headed stepchild with win 7 just like vista. My problem is that I need to use my scanner pretty often and MS doesn't have a list of supported scanners. Anyone have luck with their scanner? List you model and OS (32 or 64 bit). A couple of guys on AT forums have partial use of their scanners, but apparently none of the HP, canon or other manufacturer software works. I will have to go back to using xp if I can't use a scanner...
