Scaling 2001fp for Battlefield 2
Trinitrotoluene
As most of you know, BF2 requires a powerfull graphics card to run on a dell 2001fp at 1600x1200 native resolution with satisfactory graphic settings. I have a geforce 6800 oc 128mb card and was looking to play this game at 1280 or 1024? without having to interpolate the picture so it can fill up the screen. How would I go about making it so it will display a 1:1 pixel so black bars would be around the picture but I would get better image quality? I am using the analog connector and the option for 1:1 scaling is not available in the monitor settings. I just need to do this for a couple days because this isn't my regular monitor.
I don't believe you can, personally I just have a 9700 and I set the res to 1680x1050 and run visuals on low.... the super high res. makes up for it and it looks very nice and you dont have to deal with interpolating crap
ok cool, I had to use the DVI output on the card in order to get 'flat panel display properties' in the driver settings. THanks!
Whoa...I thought this said "Selling 2001FP for Battlefield 2"
I was just about to type something to the effect of "WHAAAT? I know BF2 is good, but not that good..."
Bah, I'm tired. :eek:
I run my at 1600x1200 but I have an X800 XT at PE speeds.
Personally as suggest above I will chose res over quality settings as at 1280x1024 will look terrible whatever the quality settings.
Trinitrotoluene said:
you need some glasses my friend.. it looks like a cartoon at any lower resolutions
I posted screenies awhile back showing one scene in NWN at native resolution, 1280, 1158 and 1024. You couldn't tell the difference in PQ except for increased jaggies which are expected whenever the resolution is notched down. I thought interpolation was outstanding as have others. On the other hand I never tried BF2, of course. In the end I just returned the thing....it sure is nice to dial in whatever resolution you want on a crappy, heavy, old-school CRT (NEC FE2111). :D
corrosive23 said:
I run it at 1024x768 with a 9700 pro on my 2001fp and there arent any black bars.
no I wanted black bars just to see the difference. I am now using my CRT to play. Have you tried playing it at the native resolution of the 2001fp? The loss of texture quality is amazing at your resolution
My maximum revolution is 1168 by something on my BF2. I have a GeForce 6600 GT. Why can't I play it at my monitor's native resoluton which is 1024 by 1280?
because DICE was being stupid
