I recently purchased a used SB65G2 from a forum member, and it's been running fine for about 4 days now. However, I recently plugged the optical audio into my reciever to test out that functionality, and discovered that it had intermitant dropouts! It doesn't seem to be related to CPU usage, and it isn't a cable issue, and my reciever works fine with other sources... so I'm out of ideas! Anyone have any ideas, or insight into this? It was overclocked previously, but I've set it back to stock FSB in an attempt to see if that was causing the dropouts, and no luck.
