SB Audigy Help
mwalt2
I just got and audigy 1 card. I was using the on-board audio on my IC7. I have a mic and headphone connection on the front of my case which I was able to connect using the internal headers on the motherboard. I do not see any labeled headers on the audigy to use for connecting the front mic/headphone jacks. Is it possible to connect the front mic and headphone jacks on the front of my case using the audigy card? Or will they work connected to the internal mobo headers even though the on-board sound is disabled? I need to connect 1 line out to my speakers, 1 to my TV, and 1 my headset. I have 1 Y-adapter I was using for my speakers and TV and using the front mic/headphone jacks for the headset. Is the best way to connect these using the audigy card just another Y-cable adapter or is there a better way?
