Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am looking for the cable that connects to the soundcard and the 5 1/4" bay. I do not know if that cable is proprietary or can be bought at a store. the model number to the soundcard is SB 0090 and the 5 1/4" model number is SB 0100
A standard 40 pin SCSI cable or an IDE cable without the pin blanks will work fine. The one in the box wasn't long enough to make it to my top bay, so I'm using a SCSI cable.
