I had problems with my motherboard so I went and bought a new cheap ECS motherboard and I had problems getting it even to post. Eventually I finally got it to show the boot screen and it would show the processor speed then not post the ram and it would just stay there. I exchanged the motherboard for the same one and got it running and started installing Vista then Vista restarted the computer and it got stuck again right after it said the processor speed it would just stick there. I then swapped out the motherboard for a DS-3 and it posted just fine and I went into the bios and it says 80 celsius for the CPU. I shut it off, cleaned the CPU paste and put paste on and reseated it and it said 80 celsius. Then I tried another fan and the same thing, about 80 celsius.
First off I am curious to know if those other motherboards could have been messed up or were having problems because the CPU was running hot? I don't want to try installing Vista again and then have the system overheat and mess up the motherboard. Should I try installing Vista and see what the CPU temps are in the operating system or should I try buying a new processor?
