Saving stuff in a TI-83 Plus
you can save them as programs using the disp command if i remember correctly.
also, notefolio might be available for the ti-83. i use it all the time on my ti89 and it works great.
check www.ticalc.org
If you wanted to be fancy, you could write a program that will prompt you for the inputs for the equation and return the answer. It's not like that's much more work than just saving the equation. :)
i dont know where my cord is. so i wanted to save some easy shit jst rigt on calc bt idk how
Save it as a program. When you want to view it, edit the program.
I can't use my 83 anymore after having my 89 titanium for so long. I used to just write programs that would solve equations for me upon entering the variables.
I do that for all of my equations. I have calc equations, econ questions, quite a few things saved as programs. Makes figuring out screen size dimensions, para equations, and several other things real simple.
PROMPT and DISP are are you need.
Heck yeah, good old AP physics with my 85, then I upgraded to the 89 in college. One program that prompted you for what you wanted to solve for and then prompted your for the variables.
Yeah, those were the good ol' days, pluggin in the variables and the 83 spits out the answer. I spent most of my time playin the games though... anyone remember Drug Lords?
