EvilAlchemist
- Jan 11, 2008
A common concern with adding a new borg for Folding @ Home is power usage.
One way to save some energy is to use Energy Efficient Light Bulbs.
Now, let me give you some numbers to look out from my Apartment.
Bathroom:Light Fixture
Original: (4) 100 Watt Incandescent Bulbs
Replaced With: (4) 14 Watt CF Energy Efficient Bulbs
Was Pulling 400 Watts while Running Now using 56 Watts
(New Lights are actually Brighter)
That 344 Watts is more then enough to run my 3 Systems in the corner.
Living room: 2 Lamps
Original: (2) 60 Watt Incandescent Bulbs
Replaced With: (2) 14 Watt CF Energy Efficient Bulbs
Was Pulling 120 Watts while Running Now using 28 Watts
One Note, I know that these numbers are assuming you leave the lights on all the time and most of us remember to turn them off, but what if you forget.
I spent $40 at a home improvement store and replaced all the bulbs in my apartment.
If I turned every light on before it would be using 1400 Watts of electricity.
Now, if every light is on 265 Watts ... huge savings .....
Note about CF Energy Efficient Lights
Most come in 3 shades:
Soft White - Has Yellow Color Similar to Normal Bumbs
Bright White - Less Yellow / More White
Day Light - White Light
We have found that the Day Light ones work well in the Bathroom and Shower.
The Soft White is better in LivingRoom / Lamps / and Dining Room
It only takes 5 minutes to change the bulbs, and 5 seconds to see your power bill drop!
![](http://www.hardfolding.com/ftag1.php/mem/571435/216/0.png)
![CF.jpg](http://www.mountaincar.com/Haywood/PostImage/CF.jpg)
