Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is there a way to save your group so you can swap between non eyefin and eyefin. I am going to be turning one of my LCDs portrait for web browsing and document prep when I am not gaming.
Profiles feature is very robust. One suggestion I can make though is to make sure it saves all CCC setings, instead of just a display group. Whenever I save all the CCC settings to a profile, it works flawlessly. But if I just save the display group to the profile, sometimes its acts all funky.
By saving all the settings, you can also save clockspeed, fan speed, and 3d settings. Which is nice, as you can lock the fan speed low for a desktop profile, and set it back to auto for a gaming profile. I also set my overclocks based on profiles too.
