Before I get flamed...yes I did search the forum.
My PCP&C supply comes with both SATA and 4-pin Molex power connectors. I'm a little concerned though by the force applied to the SATA connector as I'm stacking my drives in a HD cage at the bottom of my Lian-Li PC-601B case. As close as the drives are to each other it seems to bend the female SATA connectors on the HD itself.
If there is a clear advantage to using the SATA power connectors I will remove the connectors and press them on in a manner that doesn't cause the bending problem. Otherwise I will user the Molex 4-pin connectors which seem much more solid to me.
Comments appreciated
