SATA troubles...
xyoufailmex
Well, Im currently running a 74gb raptor. I have two issues pertaining to it...
1) Since overclocking my RAM from 200 to 240, I now get a message notifying me of my SATA setup.... this issue might not be relevant to my overclock or a tRas violation, but nonetheless....
2) I didn't notice I plugged my SATA cable into the #4 SATA slot. For OCD purposes, and the sake of new hard drives, I'd like to move this to #1, or atleast #3. Can I simply do this without losing data?
DFI Lanparty 250GB UT nForce2 motherboard s754
Athlon64 3000+ @ 2.4GHz
Corsair XMS XL 2-2-2-5 RAM 512mb
Also... after this overclock, I notice my boot times actually increased... now it takes the windows xp bar 1 1/2 times across to boot, as opposed to half way across the bar once to boot.
Thanks in advance
Not sure about your board, but my MSI has two variations on the SATA sockets. 1 and 2 are normal, but 3 and 4 are locked into PCI buss speed. That is if I lock my PCI at 66 then SATA 3 and 4 will hold at 66, thus stopping errors.
Might want to see if your board has that.
Just a thought
Alright, Im gonna hit up DFI-Street, but can you explain, or link me to an explanation, to the difference of using the PCI bus-speed on SATA, and regular SATA? Can I simply move the cable to the #1 controller in either case? Thanks
just move the cable to slot three, install the SATA drivers for that controller and you will be happy like a school girl at a BSB concert.
lol, sounds good... Where would one obtain these SATA drivers if they didn't come with my mobo... I have RAID driver which came with it... So, if this isn't required, hopping to SATA slot 3 will cure my overclock problem perhaps?
Installing the raid drivers will install the SATA drivers. you can also check the motherboard's website.
