Hi guys,
I bought a NOROCO 4220 which reguires minisas connections to the backpanels. As I am planing to use the MB SATA port and connect the backpanels, I need a reverse SATA to minisas cables not minisas to to sata as I do have those cables and they don't work.
Can anyone point me to a store where I can find the cables needed ? or is there a PCI-Express card(NOT RAID CARD) to have the minisas connectors instead of me using the sata port on the MB ? This is for a home server runing Asus Z8PE-D18 board.
Thank you
Thank you
