I've purchased 4 Maxtor Diamondmax 10 hard disks (6L300S0 model, BANC1G10 firmware) and a Promise SATAII150 TX4 controller for them.
I would really like to enable staggered spin up, which both the drives and the controller claim to support. Maxtor's documentation (here: http://www.maxtor.com/_files/maxtor...s_technical/staggerd-spin-detection-pin11.pdf ) states that you can use a jumper to force staggered spin up to be on.
If I put a jumper on each of my drives, and boot the computer, they do not spin up at all. If I take off the jumper (then the Pin 11 on the drives is grounded, I've checked with a multimeter) then the drives all start normally, but all at once (which is what I'm trying to avoid with the staggered spin up)
So has anyone managed to get staggered spin up working, and can you give me some pointers?
Thanks,
Ira
Thanks,
Ira
