Hey guys,
I pretty much rewired my entire computer over these past couple days. Everything went fine and it looks great. I did a lot of wire management, and I am pleased with how it turned out. I'll post some pics later. But first, I have a problem.
Motherboard is an ASUS A8V Deluxe
I have one 120gb HHD. I believe it was set up in Raid 0. I'm pretty sure it shouldn't be in Raid 0, but it was. Anyway, I plugged the SATA cable back in and went to boot the computer up, but of course it doesn't recgonize and hard drives.
I press tab to go into the raid array utility and it says:
Serial_Ch0 Master No Drive
Serial_Ch1 Master No Drive
It has a bunch of options to the right but it won't let me select anything, it will only let me exit.
When it comes to the Scanning IDE Drives part it says:
No drives attached to fast track controller, the bios is not installed.
Then it comes to a stop at No hard drive detected
Press F1 to resume
Do that and then it wants me to instert boot media.
So I was going to reformat anyway, so I inserted my XP cd and loaded that up, pressed F6 to load my Raid drivers, went through all that jazz and when I press enter to install XP, it says that it can't find a HHD and to press F3 to exit.
I looked in the BIOS and it wasn't listed there either.
I changed out SATA cables to see if maybe that was the prob, but nope. So i'm stumped.
Is it not recgonizing it because something is wrong physically or maybe it's a driver issue or maybe i'm totally missing something. The only thing I did really was unplug the drive and plug it back in after a couple days. I wouldn't think that it would be affected adversley.
Any suggestions would be wonderful.
Thanks in advance,
Jeff
Press F1 to resume
Thanks in advance,
Jeff
