sata raid problems on IS7 board
eornosaj
I have recently just bought a secound Western Digital 80gig sata hard drive to set a Raid on my system. I went through the bios and changed all the settings needed but when I try to format the RAID0 array in WINXP setup. I do quick format NTFS and it gives an error. I try a normal format, it stops at 100% (after an hour or so of formatting). I installed windows on an IDE drive w/ drivers for RAID and chipset. Go to Disk Management the drives are there. Try to format them there and another error. I have updated my Bios, raid controller, all that sh!t and still nothing.
WHAT IS THE DEAL WITH THIS RAID CONTROLER!!!!!!!!! OMG does anyone have SATA RAID running on this board? Please help!!!
1) Why do you want to do RAID? 9 out of 10 you probably shouldn't be doing it.
2) You have to go into the RAID config, which probably flashes right after the main POST screen.
If it's enabled in the BIOS and the drivers are installed and you've set it up properly through the RAID config util and it still doesn't work, then you have a screwy drive or a screwy controller.
its got to be the controller because the drives work fine individually. they format fine and work fine its just when its in raid.
