SATA Raid on Mothrboards
Fuzzy Logik
So I'm looking at this beautiful 10,000 RPM SATA Western Digital Raptor HDD at newegg.
I'm feeling the building excitement.
A lot of SATA capable motherboards are RAID. I will only be having one HDD, will having RAID on the motherboard and not using RAID have any performance issues?
If so... What is a suggested non-RAID SATA motherboard for this CPU:
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-499&depa=1
This is the cheapest 939 pin AMD 64, I figured to go that way instead of a more expensive less pin 64.
No, you can disable the RAID in the bios. You can even set it as IDE mode which lets you use all the SATA ports for just single drives. Like you said Raid on most of all SATA ready motherboards is pretty much standard. I wouldn't let the motherboard having RAID on it turn you away from it. Think of it as room for you to upgrade.
I just got the ASUS P5AD2-E Premium. It comes with a million features on it and still performs outstandingly.
Think of RAID on a motherboard like having integrated sound on a motherboard.
It's a feature of the motherboard but can be disabled/enabled at will and will not interfere with other operations of the motherboard whatsoever when turned off. It's just something available for anyone who wishes to use it.
-Venthos
Cool... Cool...
When dealing with circuitry like motherboards Occam's Razor is a good rule in my opinion.
When designign and manufacturing the motherboard circuitry, all those features have to be added. Just seems like more issues that could plausibly go wrong.
