SATA RAID 10 inquiry
Fx02
I'm in the process of intergrating my lab from a H/W RAID 5 to SATA RAID 10. My question is, what's the intergrity- and so forth...
Does anyone have opnions on adding a additional RAID volume from RAID 5 to RAID 10. Any opinions would be great!
Charcteristics
Code:
RAID 10 is implemented as a striped array whose segments are RAID 1 arrays
RAID 10 has the same fault tolerance as RAID level 1
RAID 10 has the same overhead for fault-tolerance as mirroring alone
High I/O rates are achieved by striping RAID 1 segments
Under certain circumstances, RAID 10 array can sustain multiple simultaneous drive failures
Excellent solution for sites that would have otherwise gone with RAID 1 but need some additional performance boost
Disadvantages
Code:
Very expensive / High overhead
All drives must move in parallel to proper track lowering sustained performance
Very limited scalability at a very high inherent cost
Source: http://www.acnc.com/04_01_10.html
You asked for opinions but my Raid knowledge isnt the greatest, so instead I'll steal someone elses.. :D
