SATA questions
3-Phase said:
What is the difference between SATA II and SATA-150? Is the only difference that SATA II has 3GB/s speed and SATA-150 has 1.5GB/s speed?
Will this hard drive support SATA II?
http://www2.newegg.com/product/product.asp?item=N82E16822144160
It says it supports Ultra/150 Command Queing. Does the Ultra refer to SATA II?
Unfortunately, the 74GB Raptor does not support SATA II. (Or, more specifically, it will run only in SATA-150 mode on a SATA II controller.) This is because the Raptor (in its current form) is not a native SATA hard drive, but rather a bridged PATA-to-SATA drive. Second, SATA II absolutely requires true NCQ (Native Command Queuing) - not TCQ (Tagged Command Queuing) - support in the drive.
Oh, by the way, Ultra/150 command queuing is Western Digital's roundabout way of claiming TCQ (not NCQ) support.
