SATA question for P4C800-E Deluxe
DirtyApe said:
i have 2 120gig HD's in RAID 0 and was wondering if i could use just one of the remaining 2 SATA ports for a single HD instead of having to buy 2 more HD's. my IDE ports are being used by a cdburner a dvd burner and a backup harddrive so i cant use them. im looking into a new high capacity HD like this one>> http://www.newegg.com/app/ViewProductDesc.asp?description=22-144-179&depa=1
and was just curious about this.
Yes is the answer :p I have the same board, and this is how i set mine up: On the Intel controller I have my RAID "0" Raptors, and on the Promise controller I have my one Maxtor 160GB SATA drive. The way to make it work in the Bios, I set the promise controller to "set as RAID" and since I boot off of this drive and not my RAID array, I set the Promise controller to "enable bootrom" Hope this helps....
that clears things up quite nicely. im going to other way though. i have my 2 120's in raid 0 and using those as my windows install and im going to add a second drive for my anime collection and other things.
