SATA PSU Mod
SKiTLz
Anyone know if you can mod your PSU to all SATA power connectors? I want it too be SATAII compliant. Which means having the 3.3V rail connected.
I havent been able to find the conenctors anywhere nor do I know how they crimp.
Cheers
EDIT: Shit.. Theres a post below me about this.. My Bad.. It doesnt have alot of info though so...
What else are you looking for?
Well where to get the connecctors... if they can in fact be crimped? That type of thing...
I can't find crimp or insulation displacement connectors yet. Molex does sell pigtailed Serial ATA power connector assemblies with 1.5 meter leads. All you would need to do is open up your power supply and solder to the appropriate contact points on the power supply board.
Molex # 88751-1410
